Old 03-28-2012, 02:28 PM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
Default Transmission
I used an engine lift an a rope choker around the transmissionto pull an install it bye myself, I got it close then put 2 long bolts in the bottom of transmission as a guide an a little jiggling it slipped into position. you need to dial your bellhousing, it needs to be plus or .05 thousands. Thats what Tremec calls for. good luck
