But, depending on which intake you are running, the front spot for the
oil filler tube could be non-existent fitted with a removable plug, as was the case with many of the Ford Sidewinder intakes. I would assume in that case that if you were using that rear breather you would need to have a filler cap on one of your valve covers.
