Old 03-30-2012, 06:29 AM
Bill Bess's Avatar
Bill Bess Bill Bess is offline
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
I remember installing diodes on the turn signals so the current wouldn't feed all four parking/turn signal lights at one time, but my memory is a bit foggy about the high beams/low beams.
Manual check: Page i28 in the Hurricane instructions says, "wire to each turn signal wire, a 1 amp diode using a butt connectiors or solder. Connect so that the triangle on the diodes will end up pointing towards the lamp". the diodes stop the current from flowing to all four signal lights at one time. Get the diodes t Radio shack.
Bill
