03-31-2012, 05:15 AM
AR
Originally Posted by wrench87
i installed my pilot bushing in the crankshaft tonight, i just wanted to see if my flywheel would fit and it wont fit over the crank hub. i have a steel 4.25 crank i got from keith craft never could get manafacturers name out of them but the flywheel is a ram aluminum 2519. does any one know what specs should be?. i just hope it is a press fit it would really suck if it was not machined properly. other rant my second quicktime bellhousings dowel pin holes are two small and do not fit i will recheck in the morning to make sure the holes are not filled with powder coating.
I would suspect it's a SCAT crank if you got it from KC.
