Old 03-31-2012, 05:26 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
it has the weights painted black?, i checked the ram flywheel it is right on spec so i will check the crank. i was surprised the bronze pilot bushing fit i pressed it in with a hub puller, i have heard people were having problems with the pilot busing area not being machined right. thanks for the information.
i think it is a rpm crankshaft, scat did not have a steel crank at the time i bought it.
it is confusing because robert pond motorsports calls his stuff rpm, but i dont they are related.
it must be a offshore vendor?.
factory five mk III roadster, 445 fe stroker
