RPM that supplies cranks is not related to Robert Pond. The crank supplier is RPMmax and are Chinese parts. Often relabeled and sold as house brands. They had a forged FE crank before Scat did - we usually have to touch grind them, and always inspect them very carefully.
The only place I have seen a bushing problem mentioned was here on this forum. Never had one myself - at least not yet - so I suspect the issue was with a short run of parts that drifted out of spec.
We find ourselves tweaking flywheels just a bit on the ID pretty often. The OE ones always fit OK so I think the problem is in the flywheel more than the cranks. Likely one going to the high ranges of spec and the other going to the low range.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
