Old 04-01-2012, 03:56 AM
Default depending on tools and ability to repair
Kramer if you have a drill press and tap set you can repair this seal in the car. Send P-m for info on how and phone# Rick L. Ps it's easy with a little work to make plate. Air gun with axle socket needed too. You will need new seal tephlon sealer and 4-6" pices of exhaust pipe that sits on the edge of the seal to install. Need to clear the pinion shaft.
