i saw a pic on gessfords site so that is all set 2 other issues starter drive is not meshing properly, and only comes out mayby 80 percent of the ring gear?.
what is the reccomended procedure to fix this. i thnk you could remove the aluminum plate of the starter and mill it down but what do i do about the mesh problem using a quicktime 6056 bellhousing.
factory five mk III roadster, 445 fe stroker
