ok i pulled the plugs and used a different jump box and installed a bat cable to the starter, the starter drive came out and turned the engine over but still does not release, if you try to restart nothing. you have to manually move the flywheel and eventually will return. here is a pic when it was engaged but not returned.
factory five mk III roadster, 445 fe stroker
