Originally Posted by PeterAllen
Rob - Thanks. Unfortunately the sideways movement is very minimal and I think I would have to have the gate just about touching the gear knob to get enough for the pattern.
No the closer you go to the gear knob the wider the spread of travel...you have to go closer to the gearbox/shift base. Instead of using a genuine Ferrari pattern you should make a similar one to suit your set-up.
