Old 04-03-2012, 09:31 PM
menace1 menace1 is offline
Ward, With the trunk mounted battery switch off, pull down the central electrical tray that is located under the LHS of the dash. You will see three relays stacked in a row on the lower RHS of the tray. The one in the middle is the relay that controls the RHS fan. With a OHM meter check that relay to see if it closed by testing the two outside terminals. If it is closed, replace the relay and your up and running again.
Glenn
