  #26 (permalink)
Old 04-04-2012, 02:28 PM
Slither's Avatar
Slither Slither is offline
Cobra Make, Engine: Alum bodied CSX4266, fuel injected alloy 472, 663 hp Engine built by Dralle. Suspension by Tom Barnard
Originally Posted by GordsFord View Post
Quote from twobjshelbys
"One thing the fuel injection does though is put a pretty hard limit on the top RPM. Mine is 6500, but the engine ought to be capable of doing something like 8000 with a good carb setup. My engine is a Roush 427IR Windsor based."
Why do you say that the fuel injection puts a pretty hard limit on the top RPM at 6500? I am planning to put the 8 Stack Injection (Classic) units on a 427 Windsor solid roller cam engine that I expect will easily rev to the 7500 rpm + range. Does anyone have comments on this?
Thanks,
Gord
I have NEVER been limited to RPM's in the 8 years I have been running the TWM stack injection and the Redline ECU! Why would the injection system put a limit on RPM? Wouldn't that fall under the ECU's performance? My engine is a Dave Dralle built all aluminum big block FE. Could there be a difference there maybe?
Don't underestimate the predictability of stupid!
