Old 04-04-2012, 05:34 PM
strictlypersonl strictlypersonl is offline
First, take Pat's advice and check the fuse to make sure you've got an actual working charging system.
For the amount you're going to use the lights, I wouldn't run their current through the ammeter at all. Take the power directly from the battery, use a relay to switch the power from the dash switch.
Unless you're going to run night races, I wouldn't bother to put in a larger alternator. You're not going to need the big lights under 50 mph, at which point you won't be using the radiator fan at the same time. Keep things simple.
