Thanks! Yeah, they look pretty cool. I tucked them in to the radiator opening, right on the front edge. I was thinking about painting the plastic covers flat black so I can switch back and forth from "obvious" to "stealth".
On the #4 fuse, it's not blown. I even checked the resistance: 0.4 Ohms.
On the power consumption, each light is rated at 55 Watts. With a "12 Volt" system (more likely 13.9 V or so...) that's 4.6 Amps each, or 9.2 Amps.
For those that don't know: Current = Voltage / Resistance; or Current = Power (Watts) / Voltage
Okay, so I'm at disconnecting the PIAA's and troubleshooting the turn signals. Where's that schematic...
DD
Dangerous Doug
"You're kidding, right?"
