Old 04-05-2012, 04:17 AM
Default Grease and a floor jack
Dangerous Doug You want these mounts tight, some times they are a little too tight. Your problem is no weight in the body. I had a motor and trans in mine. Try placing a floor jack under the arm with a small block of wood and try and press it in. It this doesn't work large hammer, block of wood, tape up the location and smack the crap out of it. She better find out now who the "BOSS" is. 4 pound plastic pallet and tape the area. Alot of grease too. Make sure the bushing in the mount is greased before putting the bolt in. GET TOUGH. good luck Rick L.
