Old 04-08-2012, 02:57 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by Gaz64 View Post
So you had a manifold vacuum leak with an I/D of 1/4 inch?
Would have been a pain to get a respectable idle.
You can convert your current base plate by adding the "idle-eze" adjustment screw, and drilling through the base of the aircleaner stud hole to make it all work.
do you have a pic of the setup or a link? i drilled through the body but am unfamiliar with how the adjustment screw setup looks.
