Old 04-09-2012, 04:49 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by Gaz64 View Post
No, the four milled slots in the top of your throttle body feed filtered air to the central bore below the aircleaner stud.
The "valve" has four holes on it's perimeter, which allows the air to enter the centre which has a blunt tapered screw residing near it's seat.
It's a simply an adjustable bypass to allow idle speed adjustment without touching the base idle setting of the throttle butterflies.
Best idea for 4 barrel carbs yet.
Pity QFT doesn't offer it.
i see. i was thinking something like a screw used for the squirters on the carb, and the brass fitting looks very similar to a fuel jet. since bg is tits up i might have to try and rig something up, plugged right now.
