Old 04-09-2012, 08:20 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You just need to cut a relief in the top of the baseplate so some air can get from the throttle bore to the center hole--then use a holley alcohol jet( or drill the one you have until you get the idle speed you want) I find that most times it takes around a .105-.110 hole to idle at 850
