Wrench87, stop all things you did up to here. I had the same problem and my starters killed all teeth from my flywheel....all guys from quicktime, Roush (where I got the parts from with my engine...) told me that there's no problem with the parts. Then I found a short video on the site from enginefactory. Here they show how you need to cut out the blockplate that the starter gets closer to the flywheel....I did this modification and since this time there's no more problem !!! Good luck and best regards from germany, Stephan
