Old 04-09-2012, 05:35 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by Jerry Clayton View Post
I've modified/blueprinted hundreds of holley type carbs for some big cam engines and generally around .105- .110 will get the idle to around 850 with the butterflies adjusted to where the transfer slots are the little perfect squars---Sometimes I take a .025 drill and reverse broack a little exact hole there with the plates just lightly snugged closed---will need about 1 1/4 turns on idle air screws
thanks for the info, i was thinking it would be easy to do to some other carbs as you described.
""Sometimes I take a .025 drill and reverse broack a little exact hole there with the plates just lightly snugged closed""
Jerry, could you describe this, i don't follow.
