Rick,
I run a NASCAR mechanical type billet CV#2526 series 110702 AB01 with the lightest CV #2522 Diaphragm w/Grey Spring, Idle PS 7-7.5 then knock the pressure down to 2.5-3 psi with a Holley regulator. I've never seen any bits of anything as my fuel fiter is between the fuel tank and the pump and I run a steel line the length of the car. The only place I run braided is from the pump> regulator> carbs. knock on wood (steering wheel wood)...
~Earl
Earl J Castillo
VP NorCal Region SAAC 2012
