Old 04-10-2012, 05:30 PM
ThePanelbeater's Avatar
ThePanelbeater ThePanelbeater is offline
The buck was generated from a female casting pulled from an original car, which then had .065 Thermal Stable wax sheets laid in to simulate the thickness of the aluminum panels. At that point, the male fiberglass plug was laid in and became the buck which you see minus the thickness of the aluminum. To date, this is the fourteenth body made from this buck.
The alloy that I am using is 1100-0 and 1100-H14 and .063 thickness.
