I was installing the diff yesterday, when I notice what looked like two vents on the Kirkham Auburn 3.42 rear diff.
The first comes out of the upper body of the diff housing with the rubber tube coming out of it. This I assume is the primary differential vent. Which I connected to the breather that is mounted in the boot (rear trunk).
Later when I was cleaning up I remembered that I had retrospectively ordered Kirkham's upgraded diff vent, which has stainless steel lines... I'll have to go back & swap out the rubber one
The second, just above the filler bolt on the rear punkin casing... has me a little confused... what is it & what is it for? what do I need to do with it?
I'm assuming it should be plugged or also vented to a breather otherwise wont it splash grease &
oil everywhere under some spirited driving as things heat up?
