Old 04-11-2012, 07:27 AM
SPDNTKT SPDNTKT is offline
Default Header Gasket Leak
Good morning,
I have a header gasket leak driver's side front cylinder. Motor is a 473 stroker FE aftermarket block, aluminum heads, etc. SPO 1465. Will I have to split the header from the sidepipe flange or can I remove the rear side pipe support to gain access to the header bolts on the motor? Do I have to jack up the motor? Any information would be greatly appreciated. Best place to puchase header gaskets?
Thanks,
Anthony
