Originally Posted by RICK LAKE
Eljaro Is this block aluminum?? If yes and you have all the pieces, it can be repaired with a good machinist and welder. You would need to add a gridle to the mains for support and drop the rpms in range to 6,000. Block would need to be welded and tubed for the oil side. Camshaft bearing area would need to be welded and recut. Rick L.
Rick, honest question. You would trust all of that block work to all the new ($$) internal parts you would have to throw inside? You have a much higher faith and trust in your block repair guy than I would. From a confidence perspective, to me it's a total do-over with all fresh components.
Eljaro, good luck with whichever direction you take...that was a tough one to look at.
