Old 04-15-2012, 05:17 AM
Silversmith Silversmith is offline
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Question
The rpm's sound great @ 80 mph! But do you know the actual rear end gear ratio? Like 354:1 or 331:1 If the actual rear end ratio is not listed in you paper work, mabe you could ask the seller. As He said he was the original seller/dealer, hopefully he will have that info. As I plan to use the same trany you have. Knowing the rear gear you now have, will help me make my final rear gear choice. Thanks m8!
