5. Does anyone know if there was a bell housing that came standard on a 6 bolt motor that has the dual transmission bolt pattern? I thought I had seen them before, but don't know what they were from. Possibly cast iron and from a truck?
Mark,
You need to look for the J-block 6 bolt bell housing from a Ford truck. They have both trans mounting patterns on them drilled but these bell housings only use the larger 164 tooth flywheel. There casting number is C5TZ-XXXX-X (something like that). This is a very heavy bell housing if you do not mind the weight.
