From memory the whole abs/traction control thing should be going.
I had to get the reluctor wheels on the back axle and get a correct ABS unit from a VE Omega or something like that as there was ABS with stability control and ABS with stability control and hot and cold running water, and ABS with XYZ.......... The Omega was a unit that only had ABS/Trac that suited my application, from memory that is. It was 2 years ago when I hunted around for these parts.
The traction control can be switched off, there's a button on the dash somewhere, like in normal commodores etc..... so if I want to do some skids on my driveway, as its a closed road, then I should be able to. Got trac as with the amount of power that will be there I thought it might be handy to have.
I stand to be corrected if thats not the case as I haven't driven it much, its currently at the trimmers, then needs final tune.....
