Old 04-24-2012, 08:53 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Many times the problems with speedos are related to the cable. Go under the dash and located the gear reversing mechanism, try to slightly loosen the cable side and see if it has any effect on the speedo operation when driving. If it does, you will need to disconnect the cable and file 1/32" off the end, reinstall and test, you can repeat this once more safely, but once usually does the trick. The other thing is to see that any bends in the cable are as long and flowing as possible. No kinks in the cable. Try this and if it doesnt work, the next thing is to try is to replace the speedometers inner cable... Contact me offline... My contact info is below.
SPFWiringDiagrams@Comcast.net
