Will go check quart by quart as I add oil, and verify my marks for 6-7-8 are accurate. Would like to know the max oil I could put in the pan and not overfill it and get into the spinning crank
Your pan itself may be an 8 quart capacity pan,you also have to add the capacity of the
oil filter,your oil lines to the remote filter and to the oil cooler and capacity of the oil cooler itself,I'm guessing all total at least 10 quarts....
David
