  #64 (permalink)
Old 04-26-2012, 08:24 PM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
All,
Got three rod caps off, none of the bearings were anything more than moderately worn...nothing into the copper or remotely near breaking up.
Wear across the face of all three bearings was not as uniform as I would think they should be (original grind on the crank not so great? ). but the crank journal didn't feel grooved ( I did have rubber gloves on).
No evidence of bluing from heat on rod or main caps. Will try to post photos after I get all the caps off.
The crank end-play was 0.006...didn't seem excessive but I do not know...the thrust bearing edges are not showing (assuming they would) and I can ONLY think of the thrust bearings breaking up as dumping enough crap into the pan to match what I have found.
Couldn't get to the mains as the support was in the way. Need to get another wrench.
ERA 289 #2027
