Old 02-21-2002, 07:24 PM
JAM1775 JAM1775 is offline
Cobra Make, Engine: SPF 974
Installing the slide ons is much easier if you lubricate the collectors inside then loosen the headers just a bit. Tap on the collectors , as there should be enough play in each header tube to move and be directed in line with the inside of collector tubes. Use the baloney tip for leverage and/or hit the collectors with a rubber mallet. Tie the collector tabs with a bolt. Bolt up the side pipes then tighten the header bolts to specs. If the headers are tight mounting the sidepipe/collector is much harder.
