Thread: Webers.....
Old 05-04-2012, 08:13 PM
Tom Howland Tom Howland is offline
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
Rick,
I made my own float spring and do not like the way it pushes the float to one side. I think I get a better adjustment using a screw driver to pull back the vert. tange to raise the float. That connection on the screw/shaft is loose. I got quite a bit difference with the two methods. Using the spring did you have to change the adjustment?
Tom
