Weber Problems & Solutions
I thought it might be good to have a thread for common issues with Webers so a person can post a problem they are having, get advise & eventually post the solution. Could also be a good place to look for answers if you experience an issue during setup or even out of the blue.
What got me thinking of this was that I had a popping issue that I had narrowed down to the Passenger side of the engine. It had just sprung up recently so I figured I'd try to focus in on what had changed lately. I have been working out my air correctors, so I pulled the jets & cleaned everything really well. I did find a small piece of debris in an idle jet(I'm guessing this may have been the cause). While I was at it, I went around the block & re-snugged the header bolts. Problem appears to be solved.
ERA FIA 2088
