  #23 (permalink)
Old 05-07-2012, 06:25 AM
Ron61's Avatar
Ron61 Ron61 is offline
I am not sure just what is possible. I carry the front plate with me and have tried a dozen ideas of how to mount one of those that slide out from under and then stand up and then can be retracted to hide the plate under the car. But the Coupe with the lift front end makes that almost impossible.
Originally Posted by grybrd123 View Post
Ron61:
I have tried to figure one out, with only limited success. Fortunately, I haven't been ticketed for no front plate (got stopped once and warned verbally). I think you could make a horizontally mounted v-shaped bracket (with the apex at the headlight end) that runs from the bottom front of the headlight relief to the inner lip of the radiator opening. You would have to drill three holes, but they would not be noticeable and if the bracket were removed, you could get nice little rubber plugs for them.
Possible?
grybrd123
SPC123
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
