Old 05-07-2012, 03:40 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by kevins2 View Post
From what I've read, having high zinc is only half the solution. Modern oils have higher detergent levels. These detergents "clean" the zinc off metal surfaces. Accordingly, a zinc additive is ineffective. Oils like Joe Gibbs have lower detergent levels as well as higher zinc content.
So, if your engine will benefit from higher zinc levels, it is probably wise to use an oil formulated with it instead of trying to add it yourself.
Regards,
Kevin
absolutely, adding zinc to a detergent oil is a waste of time.
at 60.00 a case for oil with the good stuff in,... what are you really saving by buying regular oil and putting all kinds of additives in?
Fred B
