Old 05-15-2012, 11:54 AM
Dirty Harry Dirty Harry is offline
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
You might try using a test light to confirm that 12v is being sent to the switch side of the coil consistently when the ignition switch is in the "start" position and in the "run" position. A faulty ignition switch could make you chase your tail like this if it is supplying 12v to the coil only intermittently.
When I said I wanted to be somebody, I probably should have been more specific...
