Old 02-23-2002, 10:01 AM
Cobrabill's Avatar
Cobrabill Cobrabill is offline
Cobra Make, Engine: Superformance 427 Side-Oiler
Ron,my S-O was built with a Valasco crank,Cunningham rods,Arias Pistons,Solid cam,Rockers,Shafts&related gear by Ford Power Parts,Canton RR pan,Edlebrock heads(painted),Performer RPM(all #s/letters removed)then powder-coated aluminum grey.Edlebrock H2O pump painted to match block.MSD ignition.Box&coil mounted under dash.
Carb is a Holley 850-1 3/4 bores(modified),annular discharge with 4 corner idle circuits.1-inch open phenolic spacer is underneath.Fed by a Holley blue.
The alt.bracket is a modified 70 GTO bracket.March pullies were used
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
