Thread: Hello
Old 05-21-2012, 01:09 PM
SpeedKills SpeedKills is offline
Cobra Make, Engine: SPF 427 Roush, Unique GM502 HO, AK 289 Sports (under restoration), AutoKraft MkIV 460 SVO
@Ozgur: Great work. Yes, Istanbul! You are a happy camper!. What a fantastic place for a Cobra. Would like to cruise along the Bosporus also.
Whenever in Germany welcome - contact me :-).
@ Sundude. With Cobras and ACs its can happen that you find some which are also related to some voodoo. Mine is such an example, not an Mk IV but a 289 Sports build in the 80th by Brian. Yes, such things happen. Look at Rinsey Mills "AC ACE & Cobra" page 79 - same frame/suspension I have. Four corner coil over with Konis and disc brake rear and front (the meanwhile very rare Girling ones). The body is as a 427 however smaler hips and regular without any scoop on the hood or roll bar, with spoked wheels. (Mine came with scoop and a recessed big Le Mans fuel cap, both is not peridical correct). Dash should and will be very similar to a 289 (with clock).
Fotos: Here you find some:
Die kostenlose Homepage mit page4 - Karosse
Simple play with the buttons on the top "Home", "Demontage" and "Wiederaufbau" and you can see the details.
So long
