Old 05-23-2012, 05:33 PM
patrickt patrickt is offline
Originally Posted by LG57 View Post
...I'm hearing a "klunk" noise from the rear of the car.
Before I did anything else, I would do this:
The filler and drain plugs are ½” square. Fill to about ½” below the bottom of the hole with Moroso climbing gear lube, SAE 90, part number 34800, mixed with 4 to 8 oz. of Amalie limited slip additive (part # 505-6775). If the above are not available, you may use 80W-90 GL5 lubricant with an equivalent limited slip additive. If the limited slip seems to be sticking (ratcheting around sharp corners), drain and refill, replacing the Amalie additive with 2 tubes of GM additive 1052358 or MOPAR additive 4318060AB.
