Hey Brad,
I currently have: Aviaid pan, cooler and Accusump with -12 lines and the electric valve. The starvation issue is real, proper
oil level is crucial. The 385 series tend to hold a lot of
oil up top, so the recommendation is to enlarge and radius the
oil return passages in the block and heads. It is also recommended that you enlarge the pump to filter pad feed hole from 1/2” to 9/16” and blend those entrances. (
http://www.highflowdynamics.net)
Jason
