Thread: High Oil Temps
Old 05-26-2012, 09:36 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Average race track oil temp is between 250f and 300f, .......230f is the average temp at which you would think about adding a oil cooler. I dont think you have anythingbto worry about besides the alternator, which will sutely give you problems with readings. On the battery only you will be running at about 10 to 11 volts, whereas when the alternator is charging there will be about 14 volts in the system
