Originally Posted by bliss
I have an older ERA from the late 80's. I'm thinking about having it lowered front and back for a better look. How is that accomplished and is it something difficult and expensive or relatively simple?
Thanks.
First thing you need to do is measure your ride height, as a suggestion, start with a straight shot down the center of each wheel, measure from bottom of inner wheel lip to ground and post what you have. You might also want to post your tire sizes as inner fender clearances might be an issue. Finally, see the attached url for factory ride height suggestions.
http://www.erareplicas.com/427/sampman.pdf
Page 16 will give you suggested ride heights.
Bill S.
