Old 05-28-2012, 06:51 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
For these reasons, I suggest you start with a pressure bias of about 65-75% to the front.
Good place to start. When I had the mechanical pivot, I put the car on jack stands and had someone slowly press the brake pedal. When you could no longer turn the front wheel, go to the rear and there should be very little resistance. This is only a starting point and should be fine tuned from there.
Jack
XSSIVE .....
