Squirt some
oil in #8 and see if comp comes up. That would be rings, I would think a blown head gasket would give low comp in two side by side cylinders. All plugs black and sooty could be a stuck float. Check preload on cylinder 8, see if that helps compression. Check cam lift on that cylinder. Just some little things to do before you start tearing things apart...
