Old 05-28-2012, 08:07 PM
patrickt patrickt is offline
Originally Posted by 66427stow View Post
PatrickT,
I am considering replacing the BMW MS on my ERA which is a later car, post #750. If I replace with the T 74-750 will the plastic resevoir clear the fork, or will I need to shave it? Also will,I need to shave the after boss on the MS also?
Thanks......and great information in you posts, very helpful.
The tolerance between the fork and reservoir is tight... really tight. Of course it rubbed on mine, but not enough to rub through; but damn, damn close. If you look on page 34 of the most current ERA Assembly/Service Manual you'll see the picture that I've ripped below. You know I love ERA to pieces, but man that's a tight tolerance. So..... I'm going to say there's a strong chance you'll have to buzz the fork, as per my thread on it. It's not nearly as bad a job as you might think, though... and you might get lucky and have enough room that you don't even need to do it. I do believe the Tilton requires a little grinding to fit the stock bracket, but, again, that's no big deal. Here's the rip from page 34. Tight.
