If you want help with motor mounts for FE into CCX let me know. If you put a 360 truck engine in it they fit all the valve covers, expansion tank etc and can be dressed up to look like a 427. Motor mounts are relatively cheap and easy compared to exhaust sytems and other necessary parts. I think there are some 427 Ford valve covers or adapter plates and other parts available to put on the SBC to change the appearance. Whatever makes you happy. The most common question you'll get is "Does it have a 427?" they don't ask Chev or Ford. If its set up for Chebby a BBC will drop right into SBC mounts won't it? Some of the fastest Cobras on here are Chev powered.
