Thread: Engine choices
Old 05-30-2012, 05:54 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by lippy View Post
I've ordered my ERA 427 and have begun to narrow down engine builders (another topic) and choices. I'm probably going to do a 428 but may do a 427. My goal is to have an engine that goes like stink (500hp/500 lb-ft, +/-), sounds cool with a bit of a lumpy idle, but is streetable, and not crazy expensive.
The following is a preliminary list of key choices that I need to make when I have the engine built:
- Cam lift/duration/general aggressiveness
- Intake (Blue Thunder, Edelbrock, etc.)
- Pulleys (stock/black vs. something like March)
- Geometry (e.g., stroker vs more square)
- Pistons (forged, hypereutectic, etc.)
- Carb
I'd really appreciate input on: (1) if I'm leaving anything out, and (2) what choices for each of these people do and don't like, based on their experience.
You will probably get a lot of input but ultimately it's your decison based on how much you want to spend. If money is no object (or a lesser object) an aluminum aftermarket 427 is the only choice. Anything less is somewhat of a compromise depending on your objectives for performance, appearance and bragging rights. Some folks (probably us older generation) might factor in a little nostalgia in wanting to bring an old race or hi-po motor back to life.
