  #186 (permalink)
Old 05-30-2012, 08:48 PM
xb-60's Avatar
xb-60 xb-60 is offline
Chuck and Allen - don't forget that force and pressure are two different things. If you have too much pressure then adding a 1/4" restrictor definitely will cut down the flow volume and the force at the restrictor, but it won't cut down the pressure. The pressure will be the same (except for losses, and when the thermostat is closed) everywhere in the cooling system.
Glen
