Old 02-24-2002, 11:25 AM
Whaler Whaler is offline
Default Dave
This info Bob supplied on the thread I referred you to
" The switches are VW Rabbit/Golf/Late Beetle. Part number 112 945 515G. You can probably find one at your local jobber (although I can send you a couple if you can wait). "
If yours is a three spade that simply means you have both the N.O and N.C. contacts as well as common....do you actually use all three spades?? Why not see what Napa has that is 3 spade configuration then..otherwise Bob has given you a number in the ERA applications
Tim
